Activity › Forums › Apple Final Cut Pro Legacy › Colors not as rich when I export to QT
Tarquin Boyesen replied 14 years, 1 month ago 6 Members · 16 Replies
Martin Jordan
July 4, 2011 at 6:06 pmOK…did some more digging and here’s what I found.
As I mentioned in my last post my QT files are 1920 x 1080 once they go through log & Transfer BUT those are from my 5DMKII camera’s.
I checked my QT files that were converted from my AVC-50 1080i footage from my Panasonic and after going through LT (and yes in preferences I choose Apple ProRes 422 (HQ) when I open those in Quicktime and check the inspector for info, it says these clips are 1440 x 1080 actual 1088 x 1062.
So, I opened another FCP new project and imported and 5DMKII clip FIRST and sure enough the sequence changed to 1980 x 1080. I then imported the QT file from the panny and it dropped right in BUT is still 1440 x 1080. And of course all the panny clips are from my main camera with the talent in it where I’m getting most of the washed out look.
As I have said before all clips from all cameras look well saturated in the timeline.
So with this senario I exporting a new self contained .mov with sequence settings the washed out look is still there.
Any suggestions?
Quad-Core, 2.93GHz, OS 10.6.2, 32GB Ram, external 4TB RAID eSATA, 4TB Internal, ATI Radeon HD 4870 graphics card, FCP Studio 7, AE 9.0.2, Boris BCC, FEC, CoreMelt 2, FxFactory Pro 2, idustrial revolution Volumetrix, Yanobox Motype, Squeeze for the Web, MacBook Pro (MBP) 2.6 GHz, Panasonic HPX300 Video Camera, 2 – Canon 5DMKII’s w/Pclix controllers.
The entire Adobe Creative Suite 4, Design Premium.
Owner of Full Graphics Design Firm Houston, Tx 21 yrs.
Mac user since 1988. -
Martin Jordan
July 4, 2011 at 6:56 pmThe same. When I export my large self container .mov from FCP it’s washed out there. So when I bring it into Squeeze for my final web prep that file “of course” is the same.
I have to find a way to export my original QT .mov that is as good as in my time line.
However, I have found a work around even though it requires a couple of more time consuming steps. Once I export my complete QT from FCP, I then import it again into FCP in a new project apply 15% saturation, render and then export the entire file again. Then it’s fine.
Bob Gundu
July 4, 2011 at 10:34 pmThe gamma within FCP is always a bit darker. The only way to actually see what it will look like while doing CC is to use a broadcast monitor.
Rafael Amador
July 5, 2011 at 9:22 am[Martin Jordan] “I checked my QT files that were converted from my AVC-50 1080i footage from my Panasonic and after going through LT (and yes in preferences I choose Apple ProRes 422 (HQ) when I open those in Quicktime and check the inspector for info, it says these clips are 1440 x 1080 actual 1088 x 1062.”
Your footage is not AVC-Intra (10b/HD), but plain DVCProHD: 1440 x 1080.
That’s what you get.
rafael -
Martin Jordan
July 5, 2011 at 7:29 pmWell I’m not sure why you say that. It is recorded in the camera as AVC-Intra 50 1080i. When I LT in FCP and choose the transfer preference it’s here it changes the the parameter.
So, I’m confused on your comment.
Tarquin Boyesen
August 9, 2012 at 8:41 amHERE IT IS FOLKS ! WASHED OUT OUTPUT FROM FCP FIXED !!
after tons of research here is the workaround and free!
please spread this as much as possible , I have been tearing my hair out for ages with washed out video.
I just tried this 10 mins ago and yeesshttps://byteful.com/blog/2010/07/how-to-fix-the-h264-gamma-brightness-bug-in-quicktime/
