Activity Forums Adobe Premiere Pro Colors don’t match after import in Premiere
  • Colors don’t match after import in Premiere
    Posted by Nicolas Chausson on March 21, 2018 at 5:13 pm
    I’ve got a problem in Premiere. When I import my videos, they look very unsaturated in Premiere and the picture is globaly different than my originals medias.
    I think it could be a color space issue. It’s easy to set it up in After (Project settings > color space) but I can’t find anything like this in Premiere…
    Someone knows ? 🙂
    Chris Wright replied 8 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ricky Barrow
    March 22, 2018 at 11:28 am
    Is the footage camera raw?
    Ricky
  • Nicolas Chausson
    March 26, 2018 at 2:27 pm
    No t’s a XAVC-S (H264) coming from Sony A6500.
  • Chris Wright
    March 26, 2018 at 3:21 pm
    how are u previewing them? quicktime
    uses wrong gamma. if you set vlc to openGl output, it will match premiere for rec.709. or you can get the slog2/3
    -> rec 709 lut.
  • Nicolas Chausson
    March 26, 2018 at 4:49 pm
    Thanks for your answer.
    I think it’s not a quicktime problem. When I color grade a rush in Resolve then render it, the result is exactly the same in quicktime than the Resolve monitor during the grade. But when I import this color graded rush in Premiere the color problem is also here.
    – DaVinci Resolve color space project is set to DaVinci YRGB
    – Mediainfo says that the rush rendered is in YUV
    Is that normal?
  • Chris Wright
    March 27, 2018 at 2:51 pm
    is enable fcp legacy in resolve checked? are you using video 16-235 or full 0-255? is nvidia control panel set to 0-255? how does it look with vlc?
  • Nicolas Chausson
    March 27, 2018 at 3:23 pm
    Sorry but I can’t find the checkbox “enable fcp legacy” on the Resolve 14 settings…? Where can I see if I use video in 16-235 or 0-255?
    Also, I don’t have the nvidia control panel, i’m on mac. And for VLC, the picture looks oversaturated than in resolve…
  • Chris Wright
    March 28, 2018 at 7:19 pm
    are you using video or full range?
    in color managements settings->use mac display color profile for viewers
    walter and marc talk about this.
    https://forum.blackmagicdesign.com/viewtopic.php?f=21&t=6557&start=100
