Activity › Forums › Apple Final Cut Pro Legacy › Colorista in Final Cut Pro 6 NOT working
  • Mark Maness
    June 12, 2008 at 9:11 pm
    What version of Colorista are you using? Should be 1.01
    I would suggest that you repair your permissions, trash the pref for FCP, and if that doesn’t work, reinstall Colorista.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Edward Calabig
    June 13, 2008 at 2:50 am
    Tried all of the above, still no luck.
  • Joe Bruncsak
    August 4, 2009 at 5:05 pm
    For anyone still having crashes:
    I too have been having problems with using Colorista with FCP v.6.0.5, apply Colorista to clip then the spinning beach-ball then FCP crashes. However I found a similar thread to this one on this blog:
    https://lfhd.blogspot.com/2009/05/lafcpug-colorista-demo.html
    and someone suggested removing Colorista from the “Favorites” folder under the FCP “Effects” tab. Could it be that simple? Well I did it and it worked!
    No rhyme or reason to it, all I know is I’m now working with Colorista in FCP again, crash-free. As someone posted on the blog, “Colorista doesn’t like being in the favorites folder…” YMMV, but give it a try and good luck!
    –Joe
    Joe Bruncsak
    Producer/Director
    Blue Land Media
    http://www.bluelandmedia.com
    “it’s what you imagine…”
  • William Milne
    August 21, 2009 at 9:45 am
    I’m having the same problems as The Edit Doctor, when set the fields to none, the footage splits horizontally and the upper half colours are distorted when using colorista
    If I set the fields to upper the splitting problem disappears but I get interlacing
    Did you manage to fix the problem Edit Doctor?
    Cheers
    Will
  • Mark Maness
    August 21, 2009 at 1:13 pm
    Question?
    Do you have version 1.01 of Colorista?
    If so, here’s a work around for you. Set your footage to interlaced. Put on a deinterlace filter, then use Colorista. It should work just fine after that.
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • The Edit doctor
    August 21, 2009 at 3:45 pm
    The problem was in the graphics card. I had a g5 (POWER PC) with a 4+ year old card. Purchased a better card and the problem went away….
    Now, I just have an intel model and I’m working…
  • Mike Price
    January 18, 2010 at 5:24 am
    I have final cut pro 7 and I just bought magic bullet colorista 1.0. When I open the colorista in the effects tab, only one color wheel shows in the viewer. Half of the gamma circle is visible too but the gain color wheel is hidden. Is this a glitch or am I overlooking something simple. Any help with this would be much appreciated.
  • Tom Small
    August 2, 2010 at 3:04 pm
    Not sure if you ever found the answer, but it was doing the same thing to me this morning. You just have to grab one of the vertical separators near the top and drag over to the right to reveal the other wheels. I’m trying to get it to quit crashing FCP now…
    Tom
    Tom
  • Mark Maness
    August 2, 2010 at 3:23 pm
    This isn’t a bug or error at all. This is the way the plugin works. There is no way for to to entirely fit in the default widow sizing. You have to grab the filter tab and move it off your Viewer window to use it properly. This is all in the instructions that come with Colorista.
    If this is a problem, you’re really not going to like Colorista 2.
    Wayne Carey
    Schazam Productions
  • Tom Small
    August 2, 2010 at 3:27 pm
    I didn’t have to tear the tab off at all, just drag the Column divider over to view the entire plugin. I do want Colorista 2!
    Tom
    Tom
Page 2 of 3
