Activity › Forums › Adobe After Effects Expressions › coloring text based on numbers from an array (list)
  • coloring text based on numbers from an array (list)
    Posted by Chris Gulliford on September 10, 2014 at 7:51 pm
    So I have the following expression that takes a number from a list and puts it up on the screen every six frames (30 fps). Works great. Now i need compare each number from the list to the following and change the color of the test accordingly:
    0-100 – Green
    101-140 – Yellow
    141 – 160 – Orange
    161 – Up – Red
    I’ve tried to use different animator descriptions and changing the hue/saturation, but to no avail.
    Any ideas would be greatly appreciated.
    Thanks.
    // expression to take input of series of numerical values and display them five per second or every six frames
    // get our source list
    listText = thisComp.layer("heart").text.sourceText;
    // now make an array, assuming a comma delimiter
    list = listText.split(",");
    // what's the biggest value? we'll use this as our denominator
    maximum = Math.max.apply(Math, list);
    // which number should we look at? one per six frames
    wholeSeconds = Math.floor(time-inPoint);
    milliSeconds = Math.floor(((time-inPoint) - wholeSeconds) * 1000);
    indexModifier = Math.floor(milliSeconds/200);
    target = (wholeSeconds*5) + indexModifier;
    // make sure we don't try to find the value-as-a-percentage for an out-of-bounds array number, or try to divide by zero
    if ((target >= 0) && (target < list.length) && (maximum != 0)) {
    // this will print to screen the array number or zero
    speed = list[target];
    } else speed= 0;
    Chris Gulliford replied 12 years ago 2 Members · 4 Replies
  • Dan Ebberts
    September 10, 2014 at 8:29 pm
    Assuming that you’re using an RGB fill animator and “n” represents your number, something like this for fill color should work:
    if (n <= 100)
    [0,1,0,1]
    else if (n <= 140)
    [1,1,0,1]
    else if (n <= 160)
    [1,.5,0,1]
    else
    [1,0,0,1];
    Dan
  • Chris Gulliford
    September 10, 2014 at 8:59 pm
    that works good, but returns whatever’s between the square brackets… How do I get that number to return and change in the text’s color?
    Thanks again.
  • Dan Ebberts
    September 10, 2014 at 9:35 pm
    I’m lost. I would only work as part of an expression for Fill Color.
    Dan
  • Chris Gulliford
    September 11, 2014 at 4:12 pm
    This was great! thanks…. It took me a bit to think to put the code in under “color” lol.
