Activity › Forums › Apple Final Cut Pro Legacy › COLORED TABS
COLORED TABS
Posted by Bob Vick on October 26, 2006 at 6:39 pmAt times I tend to have several projects and timelines open at the same time. Is there a way to color the tabs above the timeline window to reflect the different projects?
also any chance a newer FCP will have the Audio and Video selection visible on the logging tab within Capture and not just the clip settings?
bob
Bob Vick sr promo guy @ ch3 & CW wwmt tv, kalamazoo, mi
Jeremy Garchow replied 19 years, 10 months ago 5 Members · 5 Replies -
Shane Ross
October 26, 2006 at 8:21 pmSorry, no colored tabs.
Not quite sure what you are asking for your second question.
Shane
Littlefrog Post
http://www.lfhd.net -
Walter Biscardi
October 26, 2006 at 8:50 pm[Bob Vick] “also any chance a newer FCP will have the Audio and Video selection visible on the logging tab within Capture and not just the clip settings?”
doubtful, that will probably stay the Clip Settings tab. Just remember, anything in FCP with a tab can be pulled out to its own window so if you want it visible, just pull it out.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Bob Vick
October 26, 2006 at 9:34 pmThere have been times that I have captured only Video. Since the Capture settings stay however you last used them, I have at times captured several clips only to realize that the audio was not selected. The way my system is set up I can hear and see even if the clips settings does not have it selected. I thought that if the Audio and Video selections were visible in the logging tab under the prompt box, it would just be one more piece of information and to me a useful one. It could have a V and an A that would highlight if it is selected to be captured.
b
Mel Matsuoka
October 26, 2006 at 10:10 pm[Bob Vick] “At times I tend to have several projects and timelines open at the same time. Is there a way to color the tabs above the timeline window to reflect the different projects?”
This is actually a really great feature request that I had never thought of before…You might want to send that in to Apple’s feedback line.
Jeremy Garchow
October 27, 2006 at 6:28 pmI have sent this a bunch, it never gets in. Walter’s workwround is good, but it still gets ya sometime. A simple visual matrix would be nice right on the logging window just to let you know what you are logging and or capturing. Then you know if you need to change it or not.
Jeremy
