Activity Forums Adobe Premiere Pro Color Transitions
  • Devrim Akteke
    October 13, 2024 at 1:26 pm
    Correct me if I’m wrong but you can keyframe almost everything in the Lumetri panel and make a transition between colors. You can use adjustment layers above the two clips, add lumetri effect onto the adjustment layer, and change values there.
