Activity Forums DaVinci Resolve Color Trace – Using version 1
  • Color Trace – Using version 1
    Posted by Nat Jencks on February 8, 2014 at 12:05 am
    So a question about ColorTrace…
    The manual implies that ColorTrace always uses version 1 rather than the active grade. Is this true? If so is there a way to make it use the active grade instead, of to globally copy the currently active version into version 1 and make it the default version? Copying each grade by hand into the version 1 position seems like a non-starter. Why would is always use version 1 instead of the active version?
    -Nat
    Robert Due replied 12 years, 7 months ago 4 Members · 6 Replies
  • Paul Provost
    February 8, 2014 at 5:42 am
    See the color trace movie
    https://www.rippletraining.com/fileserve/dvr10-features/slideshow/index.html#
    http://www.filmandtvcolor.com | colorist | Los Angeles, CA
    Twitter: @4kfinish
  • Nat Jencks
    February 8, 2014 at 10:23 pm
    Thanks for the link!
    Short answer for others who have the same question: At least for 10.1, you can color trace non default versions, the manual is just wrong / not updated.
    best-
    -Nat
  • William Edwards
    February 9, 2014 at 7:25 pm
    I’ve given up using color trace for outputs as they don’t hold the proper versioning, and it can get quite confusing.
  • Nat Jencks
    February 9, 2014 at 10:02 pm
    I have to say, the only using the “default version” (v1) screwed me up in the past, but it seems to be working as I would expect currently. Just got thrown for a loop since the manual describes the old behavior.
    Best-
    -Nat
  • William Edwards
    February 10, 2014 at 3:04 pm
    So you’re finding that it links up to the ‘top’ level versions?
    My issue was that when I went to render out a piece, I would dup a sequence with addon handles of 2 seconds, then do the color trace, but it would never hold on to the versions that I was using as my final. Heck, even the tracking wouldn’t necessarily be correct. If this issue is fixed, that would be really great to know!
  • Robert Due
    February 10, 2014 at 5:55 pm
    In Resolve 10 there is no need to duplicate timelines anymore. Under the View menu you can select show current clip with handles. This allows you to track out shapes to your user selectable handle length. Then you can deselect it to go back to your timeline that displays the clips without handles.
    In project settings under Editing you can specify the project handle length. This is a major improvement!!! IMHO
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    DaVinci Resolve 10.1.1
    OSX 10.8.4
    MacPro 8-core 4,1 2.93 Ghz
    24GB RAM
    Nvidia GT120 GUI
    Cubix Expander with 2 x GTX570 (CUDA 5.0.36)
    Decklink Extreme3D+
    Panny BT-LH1710P/ Panny TH-42BT300U
    Tangent Wave
