Activity › Forums › AJA Video Systems › Color shifts during dissolves in 1080i 29.97 DVCPro HD timeline…
  • Color shifts during dissolves in 1080i 29.97 DVCPro HD timeline…
    Posted by Pierson Jacquelin on January 17, 2006 at 7:16 pm
    When dissolving from a Black and White photo (.PNG, .targa, .tiff) to black, there is a greenish cast during the event–the vectorscope backs me up.
    Anyone else notice this? My work-around is to use the opacity level control to fade to black.
    Timeline settings: DCVPro HD 29.97, Playback Quality: High, Video Processing: 8-Bit YUV, Process Max White as: White, Motion Filetering Quality: Normal.
    Any ideas?
    -P
    Larry Bell replied 20 years, 7 months ago 3 Members · 5 Replies
  • Gary Adcock
    January 17, 2006 at 7:31 pm
    [Pierson] “When dissolving from a Black and White photo (.PNG, .targa, .tiff) to black, there is a greenish cast during the event–the vectorscope backs me up.”
    if your not using any media and doing a cross dissolve to a blank canvas that is correct.
    dropping a a black slug in has been known to correct the problem.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Pierson Jacquelin
    January 17, 2006 at 7:45 pm
    [gary adcock] “dropping a a black slug in has been known to correct the problem.”
    The green shift also happens during dissolves over video. Soooo…I took your slug suggestion one step further: I nested the .PNG with a piece of slug and applied the trans to the Nest–looks fine. Laborious, but fine. I haven’t noticed this kind of thing before, though, is this endemic to DVCPro HD timelines?
    Why would slug make a difference?
    -p
  • Pierson Jacquelin
    January 17, 2006 at 8:59 pm
    Hmmmm…even with slug, there is a slight green shift that starts at frame 23 in a 45 frame dissolve from video to the nested still I created earlier, which, BTW, is a grayscale PNG.
    Strange…
    -p
  • Gary Adcock
    January 17, 2006 at 11:12 pm
    [Pierson] ” I nested the .PNG with a piece of slug and applied the trans to the Nest–looks fine. Laborious, but fine. I haven’t noticed this kind of thing before, though, is this endemic to DVCPro HD timelines? Why would slug make a difference?”
    the problem is in quicktime, you are doing an RGB > YUV conversion
    (a grayscale file is still RGB) and that is where the problem is.
    I have less of an issue with PSD or PDF files from photoshop (and yes you can use a PDF in FCP)
    you may also try changing the color space to LAB and try that.
    Gary Adcock
    Studio37
    Chicago, IL USA
  • Larry Bell
    February 14, 2006 at 2:31 pm
    Had the same problem. Apple fixed the problem. Check your sequence and make sure all of your boxes are checked in your render sequence.
