Activity › Forums › Blackmagic Design › color shift between stop and play FCP HD
Richard Scobie replied 21 years, 5 months ago 5 Members · 13 Replies
Richard Scobie
April 3, 2005 at 7:20 pm[Uwe Klimmeck] “The versions I tested didn’t do any realtime from FCP at all. After pressing the o.k.-button inside the CF plugin you could see the results. “
Hi Uwe,
I have have just resolved the same issue, but in After Effects using Color Finesse. We are on Windows, so I have no idea if this will work on Mac.
In order to get realtime updating on the Decklink monitor, the “Extend desktop onto this monitor” setting had to be enabled in Display properties for the Decklink monitor. This is the only app we use that needs this.
The “Video Preview” setting in After Effects needs to be set to “Desktop Only” and under “Settings” in Color Finesse, the Decklink monitor is chosen.
Hope this helps, as I say it’s a bit of a stretch from AE on Windows to FCP on Mac, but it might give you some ideas to try.
Regards,
Richard
Uwe Klimmeck
April 3, 2005 at 7:58 pmHi Richard,
thanks for your hint. Tried it right away but can’t make it work on my Mac and AE 6.5. Which version do you use (I only have CF 1.5 that comes bundled with AE Pro).
Would be too good to make it work somehow.Greetings
Uwe -
Richard Scobie
April 3, 2005 at 8:11 pmLikewise we are just using the CF that came with AE6.5, although there is an update available at the Synthetic Aperture site – just make sure to get the version for AE, not the standalone.
It might be worth a post to the Cow Synthetic Aperture Board, as this seems to be their official forum and like this one, gets prompt responses from the developers.
Regards,
Richard
