Activity Forums Adobe Illustrator Color settings for video
  • Color settings for video
    Posted by Gabriel Regalbuto on January 30, 2008 at 10:25 pm
    I often get logos as vector files in CMYK. Converting to RGB in After Effects or Photoshop (or even Illustrator), I lose blacks in particular, and contrast in general. Typically I pull the levels in Photoshop, or swap to black in Illustrator, but is there a particular setup I could change in my color settings to avoid the trouble?
    Thanks…
    Mike Gondek replied 18 years, 4 months ago 2 Members · 1 Reply
  • Mike Gondek
    February 11, 2008 at 2:30 am
    open your vector logo in illustrator
    File > Document Color Mode > RGB
    Select Your Logo
    Edit > Edit Colors > Convert to RGB
    If You have an older version of illustrator, I believe convert to colors was in the filter menu.
    This should fix it. If illustrator making he colors look different than in your video program, turn color management off in illustrator. In worst case manually change the RGB values in Illustrator as your vector shapes are in RGB now.
