Activity Forums Adobe After Effects Color Rendering Duller than in Program
  • Color Rendering Duller than in Program
    Posted by Topher Welsh on January 11, 2008 at 10:05 pm
    So I have footage that is around 50 mins long, that I enabled time remapping, and shortened it to 2 1/2 mins, (its of a bay outside my window)
    I added a curves adjustment layer masked of to the water, and another curves adjustment layer masked of to the sky, added a lot of contrast and enhanced the blues to the water…
    So I tried to render out to .AVI, and H.264 Quicktime and both times the color has come out duller than before… I can tell that there still have the adjustment layers affecting them, but its just not the same as what it looks like in the comp window…
    Anyone know anything that I don’t?
    Topher Welsh
    Head Editor & Motion Graphics
    http://www.scout.com
    Topher Welsh replied 18 years, 8 months ago 2 Members · 2 Replies
  • Jonathan Pitzer
    January 14, 2008 at 3:26 am
    Is this for TV or for the web. A computermonitor can display millions of colors. However, your TV screen typically only displays 256 colors. On top of this, even if you are using it on a computer, one of your settings may be set for broadcast and therefore it is reducing the number of colors.
  • Topher Welsh
    January 14, 2008 at 4:10 pm
    Ahh that would make sense… it is only being used for web, but I will check those settings… I never even thought about that… Thanks! I’ll check that when I get home and get back to you….
    Topher Welsh
