Activity Forums Adobe After Effects color profiles
  • color profiles
    Posted by Dorota Sloma on February 5, 2021 at 8:48 am
    I have a question about COLOR PROFILES when importing ILLUSTRATOR files to AFTER EFFECTS and then to PREMIER PRO. Very often the colors are so different in those 3 programs. Does anyone knows how to set up the color profiles in those three programs to have same colors while moving files?
    thank you
    Dorota Sloma replied 5 years, 6 months ago 2 Members · 2 Replies
  • Brendon Murphy
    February 5, 2021 at 2:08 pm
    Your documents will need to be in RGB space, not CMYK.
  • Dorota Sloma
    February 5, 2021 at 3:21 pm
    yes, I always set up AI files to be RGB if I want to use them in AE later but still colors are very different, especially the intensity.
    Once it worked like that: AI file very intense colors, AE very dull, then when I took the AE file to Premiere Pro it went back to be more intense, not as intense as AI bit close….
    I’m sure there are other things to click in each of these programs to make colors look same or close.
