Activity Forums Apple Final Cut Pro Legacy Color problem, need help!
  • Color problem, need help!
    Posted by Maxime Marquis on April 19, 2009 at 3:50 am
    OK, I’m a newbie so please be patient.
    I shot a dance show with my HVX200 (480 24pa) and decided to use the file scene F3, Spark. For this setting the chroma level is +4 and I think it’s part of my problem.
    The scene was pretty dark and I had to use gain, 6db. I knew that in these conditions my footage wouldn’t be great but not as bad as what I see on FCP. There’s color bleeding, if the term is right: on the right side of many object/people, there’s an colored halo (same color as the object/person). When I desaturate the colors, it’s less obvious.
    My question is: what’s the best way/filter to diminish this problem? I’d prefer to use FCP (5.1.4) but I also use After Effects 6.5
    I really need help here, thanks
    Maxime Marquis replied 17 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
