Activity Forums DaVinci Resolve Color Picker, Shapes… Mouse does not react
  • Color Picker, Shapes… Mouse does not react
    Posted by Ben Dittrich on January 2, 2012 at 7:12 pm
    Hello everyone.
    I have a Project of 40 minutes with r3d Material an tif VFX Shots.
    From the tif Shots i rendered Proxys.
    When i now work on the Project the Mouse Picker does not work
    I can’t Qualify with the Mouse…
    But when i manually adjust the settings of the hsl properties, it works.
    Same thing is happening with the shapes, i can’t use the mouse in the window , or viewer…
    But manually or via my Wave it works.
    The same thing with the Hue vs Hue….
    Because i can’t use any picker it’s really interrupting my workflow.
    Does somebody habe a solution for this Problem?
    Greetz
    Ben
    Working on DaVinci 8.2 Beta
    Mac Pro 12 Core 2,6
    Nivida Quadro
    Nivida GT
    Peter Chamberlain replied 14 years, 8 months ago 2 Members · 3 Replies
  • Peter Chamberlain
    January 3, 2012 at 1:46 am
    Just a hunch, have you opened another project to see that the picker works there?
    My guess is they picker is set to +s or -s and so when you try to pick a color to qualifier you are just adding softness to the selection.
    Peter
  • Ben Dittrich
    January 3, 2012 at 9:26 am
    The picker works in other Projects.
    Everything is selected the correct way… it just doesn’t react with the mouse when i want to pick or grab anything.
    I tried to archive and reload… didn’t work.
    Installed the older Version… didn’t work.
    Loaded the System Config… didn’t work
    In other Projects everything is fine.
  • Peter Chamberlain
    January 4, 2012 at 2:02 am
    Hi, given that it works in other projects i would just like to check again, in the qualifier tab, color picker, is the picker highlighted or the -S or +S?
    I guess you restarted the app too?
    Peter
