Activity › Forums › Adobe After Effects › Color palette within AE
Posted by Matthew Beall on August 22, 2012 at 7:33 pmIs there a way to create color palettes within AE?
I keep having to go outsite of AE, save the image, then bring it in to sample the colors..Yoan Boisjoli replied 9 months, 3 weeks ago 6 Members · 5 Replies -
Vishesh Arora
August 23, 2012 at 1:17 pmMr. Beall
Here is a Solution for this. (may be this will work for you)
Go to Edit>Preference>General
Check ” Use system Color Picker” Option.
Now you will get default color picker where you can save your color value by using “Add to Custom Colors”.
Vishesh Arora
VFX and Motion Graphics Artisthttps://digieffects.wordpress.com
Todd Kopriva
September 20, 2012 at 5:23 pmThere are some utilities for color swatches listed here:
https://aeportal.blogspot.com/2010/10/color-swatches-in-after-effects.html———————————————————————————————————
After Effects team blog
Roman Ljubimov dacko
February 6, 2015 at 2:13 pmI also thought it was annoying so I created a color palette tool that works pretty well for my needs:
Hopefully you’ll find it useful too!
Alessandro Reali
August 1, 2017 at 9:49 amI use to import in AFX, a color palette comp that I have made. No plugin, no script, free download.
https://alessandroreali.blogspot.it/2017/07/free-after-effects-color-palette-v21.html
Bye!
Yoan Boisjoli
November 20, 2025 at 9:48 pmMan, this thread is old! I landed here a while back with the same problem and no real solution, so I ended up building one.
It’s a script called Hextractor. You can paste any text with hex codes, or extract colors directly from shape layers, text, solids, and color controls. It builds a clean palette, and you can save it or generate color guides in-comp.
If it helps, here it is: https://aescripts.com/hextractor/<br data-start=”699″ data-end=”702″> Let me know what you think.
