Activity › Forums › Apple Final Cut Pro Legacy › color not going to FCP right!
  • color not going to FCP right!
    Posted by Sean Davison on October 13, 2008 at 7:40 pm
    I Took an Avid AAF – Imported it with media into FCP via Automatic Duck. Media Managed the sequence to create proper QTM Movies (Pro Res 422) Sent to Color – Graded and Rendered, then sent back to FCP – FCP says its importing the XML but links back to the original files rather than the rendered graded files. Haven’t had this happen for a while!
    Any Idea why?
    I’m re digitising the original sequence via edl/Batch Digitise – Does any one know how import CC works? Does it use clip names or the number of the shot?
    Jerry Hofmann replied 17 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 14, 2008 at 2:13 pm
    Import CC? What are you talking about?
    FCP is using clip names for connection to media files. The renders created by Color have names assigned to them by Color when they are rendered BTW… and once sent back to FCP the new sequence should reference these renders of course… ALL clips with grades done in Color must be rendered though first.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
