Activity › Forums › Maxon Cinema 4D › color matching (design)
  • color matching (design)
    Posted by Zach Gunter on July 1, 2008 at 10:15 pm
    This a actually two questions.
    1. https://www.rezn8.com/ on the promaax 2007 open video, when the promaxbda logo comes up how do you get that color. where is it white text , but hints green and yellow. the yellow looks like light colors, but the green looks built in the material. Kinda like 32bit color
    2. I have always had problems with the white material. The only way I can get something to look the white that I want is to have a glow inner set to about 20%. is there a way to make a white material without the need of the glow option (takes to long to render) Brightness does nothing, so i’m just trying to figure that out.
    Randy Johnson replied 18 years, 3 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    July 2, 2008 at 12:34 am
    1) not sure what you mean — looks like a light green to me.
    2) if you use the material color channel, the rendered result depends on your scene lighting. If you want brighter white, use brighter lights. I you don’t care about shading use the luminance channel instead of the color channel. Then you’ll get the exact color you choose.
  • Zach Gunter
    July 2, 2008 at 2:34 am
    It looks like the letters are white, the edges of them are a blueish green glow.
  • Randy Johnson
    July 2, 2008 at 11:52 am
    I think the green is in the reflection.
    /randy
