Activity Forums Adobe Photoshop color match large amount of images
  • color match large amount of images
    Posted by Marc Nibor on August 29, 2007 at 6:23 pm
    hi,
    is there a way to “batch color match” images.
    i got about 60 images which all seem to different exposure etc.
    i know how to do it manually, but i am hoping for a simpler solution.
    is there maybe a different application which specialises on this problem?
    thanks alot : )
    Abraham Chaffin replied 19 years ago 2 Members · 3 Replies
  • Abraham Chaffin
    August 29, 2007 at 8:19 pm
    Try creating an action for the match command with your settings and play it on all your images as you ctrl tab through them.
    Abraham
  • Marc Nibor
    August 31, 2007 at 10:10 am
    hi abraham,
    i’ll probably end up doing what you suggested. actually i was hoping for a “better” solution, but it seems like there is none.
    btw: i answered yesterday already two times to your post. but it never showed up and i always got an error message in my browser. is CC now incompatible with opera? it used to work before. now i use IE and it works wiout a problem.
  • Abraham Chaffin
    August 31, 2007 at 3:28 pm
    Additionally once you create the action you can use the batch command under the file menu > automate.
    This will allow you to apply an action to a folder or all opened files through PS.
    Abraham
