Color Management with DSLR/LUT
I have been trying to decipher After Effects color management system for some time, without much success. I am using a Canon 60D with technicolor’s cinestyle profile and am applying the cinestyle LUT via LUT buddy in After Effects. The issue I am having is my blacks are all over the place, and I’m not sure what colorspace I should be in (RGB or 709?). This is my workflow:
Shoot with 60D Cinestyle Technicolor Profile
Denoise source footage with Neat Video
Key footage, Color Correct, OutputThrough trial and error I have found the best results to be setting my working space to sRGB IEC and exporting in AVID DNxHD RGB. I am seeing different black levels based on my output codec (ProRes vs DNxHD). I’ve tried switching colorspaces from 8 to 16 to 32 bit, but I can’t seem to get a consistent black on my outputs.
RGB outputs look correct on my MAC at work, but they look super light on my PC at home, whereas 709 outputs look correct on my PC but severely underexposed on my MAC. I know these computers are probably using different gamma values with their displays–but despite looking at SDI 10bit outputs at home and verifying the levels, I still can’t figure out which setting is correct.
Does anyone know what the best settings for this workflow would be? Again I’m shooting on a 60D with the cinestyle profile, applying a LUT, and then outputting for youtube.
I’ve done a variety of tests, if you have time, here’s a playlist with several different color management settings: https://www.youtube.com/watch?v=FDWf5vwsfmo&list=PLGX_tWcvwRF4jbYN4zZ0YBXYe16TadglO&index=1
If anyone can help me out or refer me to a comprehensive guide on Color Management, I’d appreciate it.
