Activity Forums Adobe Premiere Pro Color Management in a 16-32bpc PPRo to AE workflow
  • Color Management in a 16-32bpc PPRo to AE workflow
    Posted by Jim Bachalo on July 12, 2011 at 12:40 am
    Hi
    Am I correct in assuming that since PPRo does NOT support any color management, you should always leave it turned OFF in AE when round tripping using dynamic link?
    Local is the new global
    Todd Kopriva replied 15 years, 1 month ago 2 Members · 3 Replies
  • Todd Kopriva
    July 12, 2011 at 12:48 am
    No.
    See the note toward the bottom of this page for how to work with color management and Dynamic Link.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Jim Bachalo
    July 12, 2011 at 2:03 am
    Thanks Todd!
    Yes read that previously but the last 2 lines seem somewhat contradictory or at the very least confusing
    //QUOTE
    ‘…colors in a composition sent to Adobe Premiere Pro or Encore using Dynamic Link are in the working color space of the After Effects project.
    To manage colors in a dynamically linked composition or for video previews, create a new composition and nest your composition within it; then apply the Color Profile Converter effect to the nested composition, with Input Profile set to Project Working Space. For video previews, then set Output Profile to match the color space of the video preview device.’
    //END QUOTE
    Back to my original question, does this mean that for a PPRO to AE color managed workflow, you should always use the Color Profile Converter effect on nested comps in AE?
  • Todd Kopriva
    July 12, 2011 at 2:09 am
    I don’t see how that’s contradictory.
    Colors sent over Dynamic Link are in the working color space for the project. To override that, use the Color Profile Converter effect to convert to a different color space—essentially doing a step of manual color management.
