Activity › Forums › VEGAS Pro › Color loss (gray) whenever i render a video
  • Graham Bernard
    October 21, 2012 at 8:10 am
    I’ve just done to Histogram analyses of your 2 samples, and sample 1 exhibits greater Contrast. Now that may appear as darker, but for my money that’s to do with the colour sampling crunching up the sampling range. The sample 2, the “lighter”, has the sampling over a wider range area.
    So, I’d be looking at the way these two renders are allowing for wider or narrower colour sampling.
    Hope that helps.
    If you want my 2 screengrabs of the Histos, then shout.
    Grazie
  • Matt Crowley
    October 21, 2012 at 10:20 am
    It looks like you’ve started with a full colour range image (pixel values 0-255, aka computer RGB) and ended up with a studio RGB image (pixel values 16-235) courtesy of the WMV codec.
    Most video codecs don’t automatically clamp/convert computer RGB to studio RGB but WMV does, presumably to prevent you having “illegal” colours in your video file. Strictly, video should only have RGB values between 16-235 (a legacy of analog TV systems), but players and codecs behave differently for different colour ranges and file types…
  • Graham Bernard
    October 21, 2012 at 11:10 am
    Matt, your analysis fits with what I’m seeing in the Histograms I’ve got.
    Grazie
  • Damien Ortiz
    October 21, 2012 at 4:19 pm
    ok, so im going to assume the easy way to fix this is to apply the studio RGB to computer RGB color correct effect?
  • Matt Crowley
    October 23, 2012 at 5:28 pm
    You can’t stop the WMV output video being 16-235 (studio) levels – that seems to be just the way it works.
    If you’re going to be uploading these to youtube, then use the AVC/MP4 format (Render As > Sony AVC or Mainconcept AVC depending on Vegas version). This should preserve the full RGB range and youtube will (I think) display it the same way.
    For some more discussion on this type of thing, see https://forums.creativecow.net/thread/24/908794
