Activity › Forums › Apple Final Cut Pro Legacy › Color Keying
  • Posted by Martin Sterling on February 2, 2007 at 7:21 am
    I am shooting green screen with a Pansonic DVX100a camera. I am using DV garage matte pro to key. If set the Easy Set Up to Uncompressed and capture from a DSR-11 deck, would the footage have better quality and give a cleaner key than DV-NTSC
    G5 Dual 2.0 GHz processor, OSX.4.8
    John Pale replied 19 years, 8 months ago 3 Members · 3 Replies
  • Shane Ross
    February 2, 2007 at 7:26 am
    Marginally. The issue is that if you shot on DV, then you already acquired the 5:1 compression that DV has. Capturing uncompressed won’t make that go away. But it will help some. Keying, color correction…always better when you capture at a higher resolution. But the weak point still is the DV compression you get right out of the gate.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Martin Sterling
    February 2, 2007 at 7:39 am
    thanx
  • John Pale
    February 2, 2007 at 8:40 am
    Of course if you master back to the DSR-11 you are going to get a DV compression hit again.
