Activity Forums Adobe After Effects Color Key question
  • Color Key question
    Posted by John Oczkowski on May 2, 2007 at 6:19 am
    Hello all,
    I have 2 different cameras available to me, and I’m trying to figure out which one would yield a better key from a greenscreen shoot using Keylight in AE. The edit will be done in SD.
    JVC D9: 4:2:2 color sampling, 480i, 50Mb/sec bitrate, ~3.3:1 compression.
    JVC HD100: 4:2:0 color sampling, HDV (1280×720) resolution (I would capture through firewire at full res, do the key, then scale down to SD), 30p, 25Mb/sec bitrate, MPEG-2 compression.
    So it seems there are pros and cons for each in terms of getting a good key. Thoughts?
    Further (and because this is the AE forum), would there be differences between the two in your keying strategy itself? (i.e. deinterlacing, blurring color channels, etc?)
    Thanks.
    Trevor Ward replied 19 years, 4 months ago 2 Members · 1 Reply
