Activity Forums Adobe Photoshop Color help
  • Color help
    Posted by Nate on May 17, 2005 at 4:13 pm
    All of the swatches in photoshop that should be red or orange have turned magenta.
    It does not matter what color management I set it to, everything stays magenta.
    Does anyone know what happened?
    Thanks in advance.
    Nate
    Jeff Kelley replied 21 years, 4 months ago 2 Members · 3 Replies
  • Jeff Kelley
    May 17, 2005 at 6:53 pm
    Turns Magenta when? printed or on the screen? If it’s on the screen make sure quick mask in not on.
  • Nate
    May 18, 2005 at 1:11 pm
    The colors are wrong on the monitor. I printed a quick test and the colors are fine on the print out. I checked and quick mask is not on. It’s weird. Anything that should be red, orange, or purple displays as magenta, but only in photoshop. If I open the same file in Image Ready or even Preview, everything looks normal.
  • Jeff Kelley
    May 18, 2005 at 2:14 pm
    You monitor might need to be calibrated or maybe it’s going bad.
