Activity Forums Adobe After Effects color grading in AE Monitor requirements
  • color grading in AE Monitor requirements
    Posted by Garnet Campbell on June 27, 2008 at 4:46 am
    I’m wanting to use AE to color correct footage for a feature length horror that was shot with the Panasonic HVX200. We’ve been editing with FCP 5.1
    Do I really need an extra card like the MXO or Blackmagic HDlink to make picture adjustments?
    I know what I want the image to look like, but can I trust what I’m seeing on my LCD screen?
    I’m interested in peoples workflow for this color grading process.
    Garnet
    http://www.theycamefromtheattic.com
    Jimmy Brunger replied 18 years, 2 months ago 4 Members · 5 Replies
  • Chris Wright
    June 27, 2008 at 6:21 am
    its all about the accurate 32 bit color reproduction. IF you can’t color correct after a monitor calibration, your going to have poor results. Basically, if your monitor fails the calibration test, and you can’t see certain colors, run…
  • Peter Van der zee
    June 27, 2008 at 11:38 am
    To my knowledge, FCP is better and more acurate and faster in color correction
    and having the system set up with YUV output to a calibrated monitor
    I suggest it’s the best way (if your only talking about color)
    http://www.zeemotion.com
  • Garnet Campbell
    June 28, 2008 at 10:01 pm
    Ya basically adjusting the RGB levels crushing the blacks a bit. I had always heard that final cuts color correction wasn’t that great. I was looking for hardware for the PC similar to the MXO box for mac. that turns a regular LCD monitor into a calibrated HD monitor.
  • Peter Van der zee
    June 30, 2008 at 9:12 am
    Sorry, don’t know about that
    guess I’m a classic, working with (tube)monitors
    but also for interlace problems that I wouldn’t see on a computermonitor
    At least here in Europe, people talk good about FCP(6) colorcorrector and Apple color
    as good tools for their purpose…
  • Jimmy Brunger
    June 30, 2008 at 11:33 pm
    Garnet,
    For PC you could try Blackmagic Design’s HD Link. Does a similar job as MXO when using Dell/Apple 23-24″ displays. Interlacing isn’t as good as MXO – but if it’s a feature film you shouldn’t be working with fields anyway.
    Of course a SONY CRT or high-end pro LCD would be your best bet via SDI, but this workflow should do you ok. Certainly better than trying to CC directly from your PC monitor!
    Just out of interest…if you’re using FCP then why are you CC’ing in After Effects on a PC? Have you tried Color that ships with FCS?
    If you want a HDLink a bit cheaper I have one I’m not using if you want to buy it.
    AE7 Pro – Nucleo – Mocha v1.2.0 – PS CS3 – FCP 5.1.4
    MacPro Quad 3GHz / ATI 1900XT / 8GB RAM / OSX 10.4.11
    30″ ACD / Wacom Intuos 3 A4 / XServe RAID
    Production Studio CS2 – Combustion 3 – Mocha v1.0.1
    Win XP Pro 32 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5s / Sony BVM-20G1E / 2 x Dell 2007FP / Wacom Intuos 3 A4 / 110GB/80GB/600GB RAID-0
