Activity › Forums › Apple Final Cut Pro Legacy › Color Grading- Comparing Clips Side by Side?
  • Color Grading- Comparing Clips Side by Side?
    Posted by Sam Swenson on March 21, 2011 at 4:32 am
    Just noticed that Boris Final Effects (AE), has the ability to color grade by comparing clips or layers that are before, or after or on different layers in that stack. This seems like a great thing.
    In FCP, are there ways to do this? Are there plugins that offer the same thing (color grade by comparing clips)? BCC 7 FxPlug has 3-way color correct, and talks about some comparison abilities, but they don’t define it like they do in the AE version presentation of features, so not sure.
    Do other tools offer something similar? Colorista, Color, or other?
    Thanks for your help!
    Sam Swenson
    Sam Swenson replied 15 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    March 21, 2011 at 7:24 am
    In FCP in the WINDOW menu, choose ARRANGE>COLOR CORRECTION.
    YOu will then see the SCOPES on the far right. But, there is a TAB called the FRAME VIEWER…that allows you to see a split screen of one of MANY options. Current frame with filters side by side with w/o filters. The current frame an previous frames…all sorts of options. Look at the drop down menus.
    Shane
  • Sam Swenson
    March 22, 2011 at 1:29 am
    Perfect. Thank you!
    Sam Swenson
