Activity › Forums › Adobe Premiere Pro › Color Finesses doesn’t see other color effects in Premiere??
  • Color Finesses doesn’t see other color effects in Premiere??
    Posted by Norman Greenwood on December 19, 2011 at 3:15 pm
    I’m sorry if this was addressed elsewhere, but I didn’t find any thread that corresponded to my issue…
    I have Color Finesse installed on Premiere Pro CS5.5, and it works well. The problem is that if I have something like Color Curves or Color Corrector, or essentially anything else affecting the color, Color Finesse doesn’t see these extra effects…?
    This makes it very hard to color correct if using any other effects, which I do regularly. It becomes a much more complicated process than it should be.
    I noticed the same issue if I have more than one Color Finesse filter as well.
    Does anyone know a way to fix this (other than outputting the clip, then bringing it back again, and then applying Color Finesse)?
    Norman Greenwood replied 14 years, 9 months ago 2 Members · 2 Replies
  • Jon Barrie
    December 19, 2011 at 5:03 pm
    Have you tried nesting?
    JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Norman Greenwood
    December 20, 2011 at 12:38 pm
    Unfortunately, it didn’t work. I thought it would too…
    I have a scene with two filters (including Color Finesse), and a color matte on a separate layer above. If I nest without the color matte I can add the 2nd Color Finesse filter. However, when it loads the CF interface it acts as though there is nothing there to color correct in the nested sequence.
    If I nest everything including the color matte layer, I can add the 2nd CF filter, but it never loads the interface (just freezes).
    Any other ideas? Thanks for the help so far.
