Activity › Forums › Adobe After Effects › Color difference key: lots of spill on talent’s legs
  • Color difference key: lots of spill on talent’s legs
    Posted by Eric Chard on January 11, 2013 at 9:12 pm
    If you go to this site:
    https://www.hollywoodcamerawork.us/greenscreenplates.html
    You can DL some great great screen practice sequences in HD, free.
    So, I’m struggling w/the first, the talent in the green screen stage w/the camera dollying to the right. There’s a lot of green spill on the talent’s legs, and while I can pull a nice key on her, her legs wind up semi-transparent.
    I’ve addressed this by doing the best key I can w/CDK, and then duplicating the layer multiple times to build up the opacity. AFAICT, this works fine. However, it feels bush-league.
    IS duplication of a keyed layer a valid workflow?
    Thanks.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Darby Edelen replied 13 years, 8 months ago 2 Members · 1 Reply
  • Darby Edelen
    January 12, 2013 at 12:57 am
    [Eric Chard] “IS duplication of a keyed layer a valid workflow?”
    Yes, but usually you’d do a separate key with different parameters on the duplicated layer to try and preserve the legs (or whatever part you happen to be working on) and then use a junk matte/mask to eliminate any issues that causes.
    Most difficult keying takes some back and forth between keying and using junk mattes/masks on several layers.
    Darby Edelen
