Activity Forums VEGAS Pro Color curves vs. Brightness & Contrast – which is better to brighten a clip up?
  • Color curves vs. Brightness & Contrast – which is better to brighten a clip up?
    Posted by Seth Kopchu on April 18, 2015 at 11:54 pm
    The film I’m currently editing has some dark spots that need brightened up. But I want to tread softly – I don’t want to brighten up an image and have it look grainy or have any sort of artifacting (or as close as I can get). I want the picture to look as clean as possible, post color-correction and whatever brightening technique I end up using.
    Here are some screenshots from my film, untouched in any way. Feel free to use them to show me the differences and what would be better for me to use in Vegas.
    Seth Kopchu replied 11 years, 4 months ago 5 Members · 12 Replies
  • 12 Replies
  • Graham Bernard
    April 19, 2015 at 6:05 am
    [Seth Kopchu] “The film I’m currently editing has some dark spots that need brightened up.”
    I went straight to NewBlue’s Colofast. It comes with 3 adjustable Levels of Luminance masking:
    Grazie
  • Bob Peterson
    April 19, 2015 at 12:13 pm
    Since you want to brighten dark spots, I think you want to use color curves. Curves allow you to limit your adjustment to a particular tonal range. You can add nodes on a color curve simply by double clicking. A node will allow you to select a range of tones to be brightened or darkened. Additional nodes will allow you to reduce or eliminate the changes applied to other tones on the scale. The brightness/contrast control does not have this ability and tends to add grain very quickly.
  • Seth Kopchu
    April 19, 2015 at 5:04 pm
    Yeah but look at how grained up that image is.
    Is this something I’m going to have to deal with, no matter the route I take to brighten the image?
  • Mike Kujbida
    April 19, 2015 at 5:17 pm
    Drop them on a timelime and look at the waveform monitor. The second and third images hardly have anything to work with. The way I see it your choices are to re-shoot with more light or put up with the noise. Sorry 🙁
  • Graham Bernard
    April 19, 2015 at 5:54 pm
    Exactly Mike. I’d like to know the back-story of how our colleague here was “given” what appears to be well sourced and acted content. Interesting.
    G
  • Aaron Star
    April 20, 2015 at 2:30 am
    google “power windows film grading” you can use a combination of blurs and cookie cutter tool to lighten areas while keeping the other dark areas from graining up to much. Then run the composite through something like Neat.
    Mostly you should reshoot that footage, and hire a camera guy that uses lights, fast lens or understands high ISO shooting.
  • Graham Bernard
    April 20, 2015 at 6:04 am
    [Aaron Star] “Mostly you should reshoot that footage, and hire a camera guy that uses lights, fast lens or understands high ISO shooting.”
    Yes. Well said Aaron.
    Grazie
  • Bob Peterson
    April 20, 2015 at 5:17 pm
    Not really. I think a cookie cutter is fixed in place unless you use a lot keyframes to keep it positioned over the area of the video that you want to effect.
  • Seth Kopchu
    April 21, 2015 at 3:41 pm
    So do you guys suggest that I color correct first, then go in and adjust the brightness, or do them both at the same time?
  • Aaron Star
    April 21, 2015 at 7:43 pm
    Color Correcting is the technical act of correcting colors that do not seem to be true for the lighting.
    Color Grading is the artistic act of adjusting color and levels to achieve a specific look.
    I would do color last, because you tend to impact saturation levels when you apply adjustments to your mids (gamma), highlights (Gain), and Blacks (Offset.) I used to use color curves mainly, then switched a long time ago to using only the Color Corrector plugin.
    The Softcon plugin may help that dark flat footage, if you like the look and have time to tinker. you can stack your plugin and change the way Softcon operates by adjusting the color corrector plugin below it.
    The cookie cutter windowing is a manual process, but what is wrong with key frames. The best art is not automated, it is a manual labor of passion. I will have 3-4 layers of windows to enhance contrast or improve latitude. If you are doing mainly handheld, you can use something like Blender to track the footage, then apply your window to a track point. There is no auto professional plugin. Plugins like magic bullet are just snake oil, being sold to people that have little creativity or patients to develop their own style.
