Activity Forums Adobe Premiere Pro Color corrections
  • Color corrections
    Posted by Kyle Weatherby on August 3, 2011 at 3:40 am
    I am new to premiere pro and editing in general I can find any place that can give me an answer on this basic question, should I do color correction first to all my clips then edit them? I thought applying the color correction to a clip then editing it would makes sense since you often take more than one cut from each clip. However when i apply my color correction to a clip and drag it back into the resource panel the clip duplicates but dose not retain any color correction, so dose this mean i have to color correct each clip and then export it, then import the color corrected clip back in to premiere then edit it? Or dose this mean i have to color correct each cut one by one once i have the sequence edited? How do i export my final project with all the sequences in order or do i export each sequence then reimport it into premiere then place the sequences in a master time line then export the final project, this is all really confusing for a new user.
    thanks
    Jeff Greenberg replied 15 years, 1 month ago 3 Members · 2 Replies
