Activity › Forums › Adobe After Effects › Color Correction Tutorial
Posted by Max_lover on January 23, 2006 at 8:56 pmHi there guys, I am looking for color correction tutorial for AE or combustion. any package because I know both packages i just need to know technique behind CC used by professional.
Thanks in advance 🙂Max_lover replied 20 years, 8 months ago 3 Members · 5 Replies -
Peter O’connell
January 23, 2006 at 9:11 pmI don’t know of a tutorial but the best colour corrector I know of for AE is the DFT colour correct plugin. Also Fnordware Powerpicker comes in handy for certain situations.
Pete -
Peter O’connell
Pete -
Max_lover
January 23, 2006 at 11:28 pmHey,
thanks for your quick reply. I use combustion mostly, and it got great CC. I dont know any professional technique or trick, I am 3d modeler, and need to polish my personal work 🙂 -
Matt Larson
January 24, 2006 at 5:07 pmhttps://tig.colorist.org/wiki2/index.php/Technical_Articles
From what I gather, this is THE rescource for high end telecine. This should get you started, also do a google search or search the COW archives for “film look” (if that’s what you are interested in–and most people seem to be!) Also, if you’re using AE 6.5 Pro, you’ll want to use Color Finesse and there is a great video tutorial here at the COW.
That should get you started and then it’s just a matter of figuring out what you like. And always always always color correct with a calibrated NTSC monitor, a computer monitor is not an NTSC monitor!
