Activity › Forums › Avid Media Composer › Color Correction Order
  • Color Correction Order
    Posted by Satesh Ramjattan on March 10, 2007 at 4:47 pm
    Hello,
    Is there a specific order that has to be set in the automatic color corrector to achieve best results.
    For example…
    Do I white balance first, then Curves, then Black Balance?
    What order are you guys using?
    I’ve tried different orders, but when applying to multiple clips, I get strange results.
    Michael Phillips replied 19 years, 6 months ago 2 Members · 1 Reply
  • Michael Phillips
    March 10, 2007 at 11:52 pm
    Auto color correction is only a starting point, and it may have an adverse effect if setting white level and you are in a low lit scene and there you don’t have much highlights…
    That being said, when using it, I do black level first, then white, then balance as a starting point, then I go and play with curves etc. to get the look I want.
    See: https://www.24p.com/colorcorrection.htm
    Michael
    anything 24fps
