Activity › Forums › Avid Media Composer › Color correction not visible as changes are made…
  • Color correction not visible as changes are made…
    Posted by Roc Barbanica on May 6, 2005 at 3:55 pm
    Xpress Pro HD- PC-
    I add the color correction effect to a clip, select the layer the clip is on, open the color correction tool. when I make changes, contrast, bright anything else, I cannot see the changes effecting the frame I’m looking at. The three at the top of the tool stay the same. Why is this and why can’t I see the changes right then.
    Of course, when I go back and render, the clip is affected.
    PLEASE HELP. This is serious!!! :-)))) I’m not kidding!
    Your friend,
    Roc-
    Chris Bové replied 21 years, 4 months ago 4 Members · 3 Replies
  • Carl Amoscato
    May 6, 2005 at 4:20 pm
    Hi Roc,
    Check Special>Render-On-the-Fly and make sure it’s turned on. This is what tells the system to show your changes as you make them.
    good luck,
    Carl
  • Tae
    May 6, 2005 at 6:58 pm
    Also, make sure you are viewing that layer, not from layers above.
  • Chris Bové
    May 12, 2005 at 8:05 pm
    Click on the little monitor next to the video track while holding (ctrl or alt – I don’t remember which). Did it turn green? good, now you’re looking at just that layer. Color correct away.
    ______
    /-o-o-\
    \`(=)`/…Pixel Monkey
    `(___)
