Activity Forums Apple Final Cut Pro Legacy Color Correction for a Green Screen
  • Color Correction for a Green Screen
    Posted by Martin Del rio on June 16, 2010 at 11:41 pm
    Hello:
    I had several problems trying to get a “clean” Chroma Key from a video footage in After Effects. My client took the video footage of the actor in front of a green screen to be color corrected before doing the chroma key. I don’t know what software the colorist used to eliminate the tiny green spills on the actor’s skin. I finally got a video file with the actor (shot in front of the green screen ) in alpha channel and I was surprised to see that even the hair had a very clean alpha as a result of the color correction to eliminate the green in order to do the chroma key.
    I honestly don’t know what the colorist did, but I just couldn’t even get closer to that in After Effects (using key light).
    Any advice on what the workflow would be after I shoot the video with the green screen?
    Thanks.
    Martin
    Jerry Hofmann replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 17, 2010 at 1:51 pm
    For starters, what format are you recording when you shoot? This makes a HUGE difference in the ability to perform a chroma key…
    It’s possible to create a ProRes 4444 file which carries alpha in FCP 7 FWIW.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
