Color Correction and Transitions
Hello,
I am encountering a somewhat annoying issue that probably has an easy shortcut.
If I’m color correcting multiple clips in my timeline with an adjustment layer and then using a transition such as dip to black between clips, is there a way to exempt that transition from the color correction? For example the black is bluish as I have shadows color corrected for more teal.
Any help is appreciated, thanks in advance!
-Dan
