Activity Forums Apple Final Cut Pro Legacy color correcting color temperature
  • color correcting color temperature
    Posted by Una Morera on October 23, 2010 at 8:35 pm
    Hello Fellow FCP users!
    I’ve got a small job editing footage that an inexperienced shooter taped. The shooter didn’t white balance and clearly didn’t understand color temperatures. The edit is mostly outdoor footage with a lovely blue hue around everyone and everything. This footage is only ending up on the web so no need to super-duper anything.. I was wondering if there was a good filter or filter setting to use to eliminate the blue. Any all suggestions are welcome!
    In kindness,
    Una Morera
    Bret Williams replied 15 years, 10 months ago 2 Members · 1 Reply
  • Bret Williams
    October 23, 2010 at 9:54 pm
    In the color corrector there is a little eyedropper and a little color swatch. It says something about color matching. Click the eye dropper and then something that is supposed to be white. Like a shirt. Once you’re happy, copy the effect, then paste onto similar clips. Maybe it’ll work across the board if the sun didn’t change much.
