Activity › Forums › Apple Final Cut Pro Legacy › Color Correct Help
Color Correct Help
Posted by Dan Herz on December 3, 2008 at 4:36 amI tweaked the color, brightness, contrast, etc. on a clip of an interview subject in a project. I got it right where I want it and now I want to copy and paste that same color correct effect onto all the other clips with that interview subject. I know this should be simple, but I can’t figure out how to do it…can someone help? thanks
Michael Gissing replied 17 years, 10 months ago 6 Members · 6 Replies -
David Roth weiss
December 3, 2008 at 4:47 amright click on the clip, copy, then paste attributes wherever you wnat and check filter
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Shane Ross
December 3, 2008 at 10:03 amHighlight the clip…press COMMAND-C…copy. Highlight all the clips you want to add this too….press OPTION-V…paste attributes. Choose FILTERS.
Shane
Read my blog, Little Frog in High Def -
Dennis Leppell
December 3, 2008 at 3:04 pmAlternatively, as you look at the visual interface for the CC filter, the upper left corner will have an icon that looks like a hand on a box. click and drag that icon to the clips on your timeline. Or, under the filter tab, you can drag the filter to the clips on your timeline.
Nicholas Bierzonski
December 3, 2008 at 3:52 pmAlso you may want to create a Color Correction Bin within your project that contains the color correction filters, and settings for each interview subject. This way you can easily copy and drag from your Color Correction Bin to future clips inserted in your edit.
-Nicholas Bierzonski
Senior Editor/DVD Author/Java Boy
http://www.finalfocusvideo.com
Dan Herz
December 3, 2008 at 5:26 pmThanks for all the help. I’m sure I can figure it out from here…many thanks
Dan
Michael Gissing
December 3, 2008 at 11:09 pmBeware of copy >paste attributes if you have any other filters on that clip. It will copy all filters.
The idea of dragging the grade to a bin and then dropping onto multiple selected clips is safer. A little tip with that. If like me you might have two or three filters and you want to apply them in order, then rename them in the bin and make sure they sort in the order you want. Highlight all filters and then drag onto multiple clip selection.
