Activity › Forums › Apple Final Cut Pro Legacy › color change to only part of the screen?
  • Kevin Monahan
    May 6, 2005 at 5:51 pm
    Stack up identical clips. Place a Matte>Mask Shape on the V2 clip. Color Correct the V1 clip and there you go.
    OR did you want to isolate a particular color? That’s a different technique.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Ryanservant
    May 6, 2005 at 7:17 pm
    well I am doing a green screen and the bottom right corner wont key out for me…..so I was thinking about making the green look more brown to match the background plate.
    G5
    xserve 2.5 TB
    FCP HD
    2 gigs ram
    Used to be Kona Hd…Now its Decklink HD pro
    Ryan Servant
    AirSeaLand Productions
    http://www.airsealand.com
    718-626-2646
  • John Fishback
    May 6, 2005 at 9:18 pm
    Do as Kevin suggests, and apply a different chroma key to that area so it works.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
