Activity › Forums › AJA Video Systems › Color can lock up Kona 3 on Export
  • Jeremy Garchow
    June 19, 2007 at 2:49 am
    Can you apple-tab to the finder and then back to FCP?
  • Walter Biscardi
    June 19, 2007 at 4:00 am
    [JeremyG] “Can you apple-tab to the finder and then back to FCP?”
    I get the “FCP Not Responding” lockup once it starts. Haven’t been able to get it out of that once it starts. Good news is Color now holds on to the renders so you can always “Re-send” to Color if you lock up the project before saving.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Gary Adcock
    June 19, 2007 at 11:09 am
    [walter biscardi] “I get the “FCP Not Responding” lockup once it starts. Haven’t been able to get it out of that once it starts. Good news is Color now holds on to the renders so you can always “Re-send” to Color if you lock up the project before saving.”
    have not seen that one, careful on the resend — you can corrupt the path to the renders when you resend them from the same project multiple times.
    Is this on your clean install version? I found this possible with old Final Touch prefs on the machine, but not with a clean install.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Walter Biscardi
    June 19, 2007 at 11:12 am
    [gary adcock] “Is this on your clean install version? I found this possible with old Final Touch prefs on the machine, but not with a clean install.”
    To put it nicely, all things Final Touch were excorsized from this machine a long time ago.
  • Santiago Gutierrez
    June 20, 2007 at 2:34 pm
    I have this issue also every time i send from Color to Final Cut Pro. What works for me is as suggested above to Command-Tab to the Finder, but wait until the Kona 3 switches to the Multi Pattern, or Color Bars, or whatever test pattern you’ve got set up. I do this immediately once the XML import finishes in Final Cut Pro. I do no operations in FCP until I’ve done this. Once the test pattern goes on in the Finder, I then switch to FCP and work as normal, no need to quit Color. This works every time for me.
    Santiago
