Activity Forums VEGAS Pro Color blue turned black in the preview of my video project
  • Color blue turned black in the preview of my video project
    Posted by Willem Dermaut on April 22, 2020 at 5:02 pm
    I made a fairly long and complex video with sony vegas pro 13, I recently noticed that my blue colors were turned black in the preview window. When I start a new project my blue colors appear, so I probably changed something in my project, but I don’t know what.
    For example, if I add from the media generator tab the solid color blue, it shows as black in my preview screen.
    Appreciate all the help you can give me!
    Graham Bernard replied 6 years, 4 months ago 2 Members · 12 Replies
  • 12 Replies
  • Graham Bernard
    April 23, 2020 at 1:07 am
    [willem dermaut] “For example, if I add from the media generator tab the solid color blue, it shows as black in my preview screen.”
    Hi Willem! That’s an excellent Controlled test. Need a detailed ScreenGrab of your Timeline to determine just what you’ve done. Are you adding the Blue to a New Project?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Graham Bernard
    April 23, 2020 at 4:00 am
    What do your Scopes tell you?
    * Grazie
  • Graham Bernard
    April 23, 2020 at 5:52 am
    VectorScope for BLUE. This is what I mean:
    Can you SEE that tiny Dot in the Blue area?
    * Grazie
  • Graham Bernard
    April 23, 2020 at 5:56 am
    Same in your VP13:
    * Grazie
  • Willem Dermaut
    April 23, 2020 at 8:30 am
    My Vectorscope indeed doesn’t look like it should
    another screenshot to clearly visualize the problem:
    Thanks for the quick and clear reply, if you need other information or screenshots let me know.
  • Graham Bernard
    April 23, 2020 at 9:09 am
    [willem dermaut] “My Vectorscope indeed doesn’t look like it should”
    Willem, it would appear you have an ACTIVE Project FX:
    Why? And what is it? We have discovered the Culprit.
    * Grazie
  • Graham Bernard
    April 23, 2020 at 9:10 am
    Quick Test is to Click on the FX Bypass on the Preview Toolbar.
    * Grazie
  • Graham Bernard
    April 23, 2020 at 9:17 am
    We MAY have discovered the culprit. It’s called the Video Output FX and affects ALL the Project.
    * Grazie
  • Willem Dermaut
    April 23, 2020 at 9:58 am
    Yep, I disabled it and my project became blue again! I didn’t really know about this function, so I must’ve pressed it by mistake.
    Anyway, thank you very much for the help, truly a lifesaver!
  • Graham Bernard
    April 23, 2020 at 10:29 am
    [willem dermaut] “Yep, I disabled it and my project became blue again! I didn’t really know about this function, so I must’ve pressed it by mistake.”
    Well you’ve Bypassed the FX. If that CHAIN Icon is still GREEN then you do have an Active FX. Click on it to discover just what VIDEO FX you have. Clicking on BY PASS isn’t a solution. Do you understand?
    * Grazie
