Activity › Forums › Apple Final Cut Pro Legacy › Color bars
Color bars
Posted by Oliver Jones on February 27, 2009 at 4:11 pmHi,
I was recently asked to produce a master of my film on Beta SP for broadcast with at least 30 seconds of color bars at the beginning.
Which is the best/standard color bar option to use?
Thanks.
Walter Biscardi replied 17 years, 7 months ago 4 Members · 4 Replies -
Alex Elkins
February 27, 2009 at 5:13 pmIf you’re in the UK the standard is to use ‘Full Frame’ bars with tone at -18dB.
Simplest way to know what you need for certain is to ask the channel for their delivery spec document – it will give you all of the information you need. -
Oliver Jones
February 27, 2009 at 6:48 pmI suppose the best is to use “Mire et 1000 Hz PAL” (in French) in Video Generators right?
Michael Gissing
February 28, 2009 at 5:13 amActually, on beta SP the 1khz tone should be set to 0 VU. -18dbfs is only for digital scale machines, not old analog SP.
I would assume full frame 75% bars but it varies depending on broadcasters. International masters that I produce always have full frame 75% bars.
Walter Biscardi
February 28, 2009 at 11:26 am[Michael Gissing] “Actually, on beta SP the 1khz tone should be set to 0 VU. -18dbfs is only for digital scale machines, not old analog SP. “
-18 is generally what you will set your FCP Bars to for setup at 0 analog. Why FCP sets up to -12 as default is beyond me.
And all the networks we deliver to require -20 for Bars on any digital master both SD and HD.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
