Activity › Forums › Adobe After Effects › color along a spline
  • color along a spline
    Posted by Tom Ma on August 6, 2013 at 5:39 pm
    I would like to create a stroke along a spline, but have the color start and end in different colors.
    Trapcode Red Giant 3D stroke comes to mind, but does not have the color functionality.
    Any ideas?
    Roland R. kahlenberg replied 13 years, 1 month ago 3 Members · 2 Replies
  • Doyle Lewis
    August 6, 2013 at 6:07 pm
    If it doesn’t cross back over itself, you might be able to use it as a lumma matte over a solid with like a 4-color gradient effect or something.
    Doyle Lewis, Assistant Videographer
    thinkck.com
  • Roland R. kahlenberg
    August 7, 2013 at 9:19 pm
    Use a Shape Layer to create the spline/path. Ensure to switch off the Fill property for the Shape Layer. Apply the Gradient Stroke Shape Operator.
    The Gradient Stroke’s start and end points can be observed in the Comp Panel as a dashed line with two dots on either end. Move the start and end points accordingly. Set the gradient’s start and end color to taste.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
