Activity › Forums › Adobe After Effects › Collapsing words into acronyms
  • Collapsing words into acronyms
    Posted by Brittany Jones on September 16, 2022 at 12:26 am
    Hi everyone! Does anyone know a way that I could collapse a few words into an acronym? Just as an example, if I was collapsing/morphing “As Soon As Possible” into “ASAP” in a sequence, is there a way that I could animate that? I’ve tried looking up tutorials online, but can only find words morphing into other words. Hoping to have a collapsing effect. Thank you!
    Eric Santiago replied 4 years ago 4 Members · 3 Replies
  • Andy Kiernan
    September 16, 2022 at 3:03 pm
    Maybe you can use the split() function to take the letters you need onto another text layer, then do a transition animation, doesn’t really help make a morph, but if you need to do this many times, it may speed you up? or maybe not…
    Tip 037 – Split Method in After Effects – YouTube
  • Filip Vandueren
    September 17, 2022 at 1:37 pm
    What would you want the extra letters do ? Squish together until they are width 0? Fade out, then the remaining letters merge? Move out of the way in a different manner ? I think you need to design an example first, hand animate it, and then we can think about how to Automate that.
  • Eric Santiago
    September 17, 2022 at 6:11 pm
    I’ve had to do this many times.
    I use the evaporate for the letters I don’t want.
    I use the sleight of hand trick where you use the whole word and then animate in the final characters.
    So many different options to do this.
