Activity Forums Adobe After Effects Expressions collapsing layer attributes via java script
  • collapsing layer attributes via java script
    Posted by Christian Stejnar on May 2, 2008 at 4:40 pm
    hi all,
    does anyone happen to know which java script method of the layerobject-class is the right one to “twirl” in and out the attributes of a layer in the timeline panel.
    what i would like to do is for example in a comp with a bunch of layers – each of those layers shows us different attributes per layer like position, rotation, scaling etc – i´d like to collapse all layers to the reduced view just showing the layer without any attributes.
    any ideas?
    nice greetings
    chris
    Christian Stejnar replied 18 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 2, 2008 at 5:59 pm
    Hmmmm… duplicate each layer and delete the original?
    Dan
  • Christian Stejnar
    May 2, 2008 at 6:29 pm
    mhhhh – that would work – yes. but i am a little bit concerned about the duplicate workflow – maybe i can work out a different solution – anyway – thx!!
    chris
