Activity Forums Adobe After Effects Collapse transformations changing motion?
  • Collapse transformations changing motion?
    Posted by Mike Mackenzie on September 20, 2013 at 2:52 pm
    Hey everyone…
    I was working on a project, and when I enabled Collapse Transformations to the four AI layers, it drastically changed the animation as you can see here: https://youtu.be/0ymqbSRSBP4 the motion is now rather jerky.
    This was animated using Radial Wipe. The keyframes were not eased. Any idea why this happens? I will fix by pre-rendering but I’d like to know what’s up with this so I can resolve it properly in the future.
    PS each arrow quadrant is it’s own animated layer because the heads and tails overlap slightly and I wanted one to finish before the next began.
    Motion Graphics Designer / Art Director
    Boston, MA
    System:
    Mountain Lion on SSD
    2 x 2.8 GHz Quad-Core Intel Xeon
    NVIDIA Quadro FX 4800
    18 GB RAM
    Mike Mackenzie replied 13 years ago 2 Members · 2 Replies
  • Darby Edelen
    September 20, 2013 at 5:06 pm
    Effects are no longer in Layer Space when a layer has its continuously rasterize/collapse transformations switch enabled. Instead the effect acts in Composition Space. The easiest way to think about this is that the effect no longer looks at the layer’s boundaries or transformations, instead it acts in the composition’s boundaries and transformation space.
    For example, if you have an effect that creates a radial wipe beginning from [0,0] on a source layer and you continuously rasterize that source layer the center of the radial wipe will now be [0,0] in the composition which is always the upper left corner, even if the layer is moved or rotated the center of the radial wipe will be [0,0]. Not only that but the starting degree of the radial wipe, if it’s 0 degrees, will always point straight up in the composition no matter how you rotate the layer.
    While this may seem like a problem initially, it can actually be quite useful once you understand how it works. In your case, for example, you could enable continuous rasterization then place the center of the radial wipe at the center of the four layers (you could even use a Null object to represent the center of the radial wipe, link it by expression, and parent the 4 footage layers to it). Now animate the radial wipe on one layer from 0% to 100% completion over the duration you want the entire transition of all four layers to take. Copy this effect and paste it to the other 3 layers.
    Alternatively, use an Adjustment Layer to do the above. It would actually be simpler in this case but you wouldn’t get the same insight into how continuous rasterization works 🙂
    Darby Edelen
  • Mike Mackenzie
    September 20, 2013 at 8:00 pm
    Very enlightening, thanks man!
    Boston, MA
    System:
    18 GB RAM
