Activity › Forums › Adobe Photoshop › Collage with masks – Smart Objects NG, and Transform NG…
  • Collage with masks – Smart Objects NG, and Transform NG…
    Posted by Mark Palmos on June 29, 2017 at 8:49 pm
    Hello all,
    I am trying to make a collage of about 15 images on an A3 sized sheet. Many of the images will need to be resized, cropped, and sometimes masked with gradient transparencies… sounds easy but…
    I dragged the pix to the A3 Photoshop document, and each had to be double clicked as each gets placed with the transform tool active. Odd, but ok.
    The problem is I found I could not select an area of any photos to delete the rest, it said Smart Objects are not directly editable. (also odd)
    So I read up about importing images in a Stack, and they arrive as layers instead of Smart Objects. These can be transformed and cropped, masked and everything I need, BUT transforming them down apparently resamples them for some reason, so you loose a lot of quality.
    So what to do? It seems this very basic need is actually fraught with gotchas… caught between a rock and a hard place… or is there a third way of doing this simple collage?
    Mark.
    Mark Palmos replied 9 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
