Activity Forums Creative Community Conversations Codecs info change ?
  • Codecs info change ?
    Posted by Roger Clark on July 11, 2011 at 2:43 pm
    Quick question,
    Even though I’ve transcoded my footage it still displays H.264,Linear PCM in my Codecs: box in the Inspector info.
    I’m trying to find the cause of my sometimes choppy timeline, which will disappear if I re-start FCP-X.
    I’m on a MacBook Pro , 2.66GHz Intel Core 2 Duo with 4gb ram and a Lacie 7200 rpm 320 GB partitioned external Hard Drive ( 100 GB available ) connected by FW 800. It’s a 16 min movie.
    Thanking you in advance, Roger
    Rick Lang replied 15 years, 2 months ago 2 Members · 3 Replies
  • Rick Lang
    July 14, 2011 at 4:31 pm
    Roger, I believe memory is fairly inexpensive now and it may help your overall performance if your Macbook was running with 8 GB memory instead of 4 GB. It still sounds like FCP X has some areas where it either can’t keep up with something that is contending for the CPU or there may be a bug somewhere that’s causing the temporary stumbles. Regardless more memory will likely reduce the chance of this happening.
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
  • Roger Clark
    July 15, 2011 at 1:15 am
    Thanks Rick, I’m going for more memory but I still can’t understand why the codec info does not change in the Inspector when I’ve transcoded it ?
  • Rick Lang
    July 15, 2011 at 4:00 am
    Did you transcode it outside FCP X from H.264 or did you transcode it as part of the Import into FCP X or transcode it some time after you had completed the Import?
    If it says it’s H.264 in the Inspector, what happens when you select a clip and try to transcode it (again)? Does it then tell you the code is already ProRes? If the answer is “yes”, that’s certainly a strange bug although perhaps there’s some hidden metadata that retains the original codec.
    Rick Lang
