Activity Forums Adobe After Effects Codecs from AE : ProRes 4444 10 bit?
  • Codecs from AE : ProRes 4444 10 bit?
    Posted by Alexander Ryan on August 24, 2015 at 6:12 pm
    Hello,
    I’ve got a client that’s requesting delivery for this giant screen to be a ProRes 4444 10 Bit quicktime. Is this even possible? My understanding is that ProRes 4444 is 16 bit w/ alpha channel. Remove the alpha channel, you get 12-bit. R, B, & B channels equal 4 bits each, equalling 12 Bit. If they are asking for 10 Bit 4444, is that even possible?
    Before I respond to the client, I am hoping to have my head wrapped around this subject. I’ve got no editorial support here, so I’m trying to keep the workflow in After Effects, if it’s possible to render/export at this spec.
    Thanks for reading!
    Alexander Ryan replied 11 years ago 2 Members · 2 Replies
  • Ivan Myles
    August 24, 2015 at 7:25 pm
    You are confusing bits per channel with bits per pixel (or picture element). It’s 8-, 10-, 12-, or 16-bits per channel, which refers to the number of graduations from zero to full for each channel (e.g. 256, 1024, etc.). In practice, set the AE project to 16-bit and export using “Billions of Colors.”
    Here is some reference information on the codec:
    Apple ProRes White Paper
  • Alexander Ryan
    August 24, 2015 at 11:09 pm
    thanks very much, that was helpful
