Activity › Forums › Adobe After Effects › CODECS and Transcoding
  • CODECS and Transcoding
    Posted by Christopher Rotter on January 20, 2012 at 12:26 am
    Any suggestions on TransCoding Software ? I’m presently using Prism File Converter. I want to know if there any other options available ? I need to trancode video of any format to the formats below without loosing any quality. Are there any CoDecs in the list that are insignificant and useless ?
    Quicktime DV / DVCAM
    Quicktime DVCPRO
    Quicktime DVCPRO 50
    Quicktime DVCPRO HD
    Quicktime H.264 (playback performance dependant on CPU – transcode recommended) (What is different about QT h.264 over other h.264, because the video editor won’t load other variants of h.264 ?)
    Quicktime AVCHD (playback performance dependant on CPU – transcode recommended)
    Quicktime Photojpeg (playback performance dependant on CPU – transcode recommended)
    MXF OpAtom DVCPRO (P2)
    MXF OpAtom DVCPRO 50 (P2)
    MXF OpAtom DVCPRO HD (P2)
    MXF Op1a DV / DVCAM (XDCAM)
    MXF Op1a MPEG-2 SD I-Frame (10Mb/s – 50Mb/s)
    MXF Op1a MPEG-2 HD I-Frame (50Mb/s – 300Mb/s)
    AVI DV / DVCAM
    AVI DVCPRO
    AVI DVCPRO 50
    AVI DVCPRO HD
    AVI Uncompressed SD
    AVI Uncompressed HD
    AVI MPEG-2 SD I-Frame
    AVI MPEG-2 HD I-Frame
    AVI MJPEG
    These are the following Video and Audio CODECS on my PC. Do any of them work with the formats I need to convert to with the above list, none match but in-case the algorithms behind the scene are the same ? Are there any video and audio codecs listed below that are old I can uninstall rather then having them on my system ?
    Video Codecs
    ICM Microsoft RLE MRLE msrle32.dll 6.1.7601.17514
    ICM Microsoft Video 1 MSVC msvidc32.dll 6.1.7601.17514
    ICM Microsoft YUV UYVY msyuv.dll 6.1.7601.17514
    ICM Intel IYUV codec IYUV iyuv_32.dll 6.1.7601.17514
    ICM Helix I420 YUV Codec I420 i420vfw.dll 1.3.0.0
    ICM Toshiba YUV Codec Y411 tsbyuv.dll 6.1.7601.17514
    ICM Cinepak Codec by Radius cvid iccvid.dll 1.10.0.13
    ICM TechSmith Screen Capture Codec tscc tsccvid.dll 2.0.6.0
    ICM Helix YV12 YUV Codec YV12 yv12vfw.dll 1.3.0.0
    ICM Lossless RGBA compression LWLR
    DMO Mpeg4s Decoder DMO mp4s, MP4S, m4s2, M4S2, MP4V, mp4v, XVID, xvid, DIVX, DX50 mp4sdecd.dll 6.1.7600.16385
    DMO WMV Screen decoder DMO MSS1, MSS2 wmvsdecd.dll 6.1.7601.17514
    DMO WMVideo Decoder DMO WMV1, WMV2, WMV3, WMVA, WVC1, WMVP, WVP2 wmvdecod.dll 6.1.7601.17514
    DMO Mpeg43 Decoder DMO mp43, MP43 mp43decd.dll 6.1.7600.16385
    DMO Mpeg4 Decoder DMO MPG4, mpg4, mp42, MP42
    Audio Codecs
    ACM Microsoft IMA ADPCM CODEC 0011 imaadp32.acm 6.1.7600.16385
    ACM Microsoft CCITT G.711 A-Law and u-Law CODEC 0007 msg711.acm 6.1.7600.16385
    ACM Microsoft GSM 6.10 Audio CODEC 0031 msgsm32.acm 6.1.7600.16385
    ACM Microsoft ADPCM CODEC 0002 msadp32.acm 6.1.7600.16385
    ACM Fraunhofer IIS MPEG Layer-3 Codec (decode only) 0055 l3codeca.acm 1.9.0.401
    ACM Microsoft PCM Converter 0001
    DMO WMAudio Decoder DMO 0160, 0161, 0162, 0163 WMADMOD.DLL 6.1.7601.17514
    DMO WMAPro over S/PDIF DMO 0162 WMADMOD.DLL 6.1.7601.17514
    DMO WMSpeech Decoder DMO 000A, 000B WMSPDMOD.DLL 6.1.7601.17514
    DMO MP3 Decoder DMO 0055 mp3dmod.dll 6.1.7600.16385
    I’ve installed the Avid DNxHD codec but it’s not listed ?
    Jeff Meyer replied 14 years, 8 months ago 5 Members · 15 Replies
  • 15 Replies
  • Ben G unguren
    January 20, 2012 at 12:56 am
    Make sure qt is installed on your pc, which will put a lot of your listed codecs on your pc if they aren’t there already.. I suggest MPEG Streamclip as an excellent free app for transcoding. Adobe Media Encoder is terrific if you have it….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Christopher Rotter
    January 20, 2012 at 3:49 pm
    Any other options besides the original QT ? The codecs listed in the second part of my message, is there any in that list, I can delete that are old ?
  • Walter Soyka
    January 20, 2012 at 5:12 pm
    I’m trying to understand the question behind the questions you’re asking.
    What is it that you’re really trying to accomplish? What’s your workflow like? Why do you want to delete codecs from your system?
    Walter Soyka
  • Kevin Camin
    January 20, 2012 at 5:21 pm
    You’re going to lose quality whenever you transcode, unless you are going to an uncompressed format. That’s why you often transcode in the first place, to reduce the file size so it’s more manageable during the edit or for final output.
    You can think of codecs like file types. In Photoshop you can make jpegs, tiffs, pngs, gifs, psds, etc. A tiff, psd, or png is lossless, meaning it is uncompressed and unaltered. These files can be big. Whereas a jpeg will create a very small file by performing an algorithm to simplify the visual data; I believe it averages clusters of pixels and reduces the number of colors. In video, the ‘animation’ codec and ‘png sequence’ codec is a lossless codec. No compression is taking place and the files tend to be big. A QT h264 file on the other hand is very compressed and creates smaller files which tend to work well for computer playback and streaming.
    I agree that Quicktime Pro 7 is the best $35 you’ll spend. If you need to make a .wmv for PC, you can buy Flip4Mac that works seamlessly with Quicktime Pro 7. Flip4Mac is more expensive but is necessary (and thank god it exists) if you need to make PC compatible files.
    I tend to favor Quicktime Pro 7 over Adobe Media Converter for transcoding. I find I get better results for unknown reasons to me.
    Best regards,
    Kevin Camin
    January 20, 2012 at 6:19 pm
    I want to TransCode/convert video to one of the CoDecs I listed in the first part of my message. I also want to know which of those CoDecs in the top part of my original message that I can eliminate from that list because of their life and reliability etc ?
    In the second part of my message I listed all the Audio & Video CoDecs installed on my computer. Which of them can I delete ? I want to keep Audio and Video CoDecs that are beneficial, not collecting dust on my computer, up to this point I never use. Unless some of the CoDecs installed are tied in with other things on the system ?
    January 20, 2012 at 6:22 pm
    If I don’t want to purchase QT Pro, I want to go another free / open source route is there any other options that can fulfill what everyone in this thread is saying QT Pro can do specifically, to what my goal is ?
    @ Kevin – Thank you for that info 🙂
  • Walter Soyka
    January 20, 2012 at 7:12 pm
    [Christopher Rotter] “I want to TransCode/convert video to one of the CoDecs I listed in the first part of my message.”
    I know what you asked — but I want to know why you’re asking it, so we can try to give you a better answer in the context of the work you’re actually trying to do. We may be able to offer suggestions on the workflow as a whole.
    In other words, don’t ask a plumber the best way to collect the water that’s leaking from your sink — ask him the best way to fix the leak!
    Of course, it could be that transcoding is the best option, but in that case, knowing more about your workflow would help us help you with codec selection.
    [Christopher Rotter] ” I also want to know which of those CoDecs in the top part of my original message that I can eliminate from that list because of their life and reliability etc ?”
    No need for the mixed case — everyone just calls them codecs.
    The codecs you use depend on what camera you acquire with, the editorial software you use, and what formats you’re expected to deliver to. This question is next to impossible to answer in the general case, because any one of them may be suitable in some cases but not in others.
    [Christopher Rotter] “In the second part of my message I listed all the Audio & Video CoDecs installed on my computer. Which of them can I delete ? I want to keep Audio and Video CoDecs that are beneficial, not collecting dust on my computer, up to this point I never use. Unless some of the CoDecs installed are tied in with other things on the system ?”
    I agree with Dave — don’t delete a single one. Any disk savings would be negligible, so there’s little benefit from removing the standard install codecs when compared with the risk of some application needing a specific codec later.
    Walter Soyka
    January 20, 2012 at 9:08 pm
    I need to take a few clips and convert them, so the software that I’m using can read them. In my original message the first part of the message I posted a list of codecs. Those codecs are the ones that the software can only read. I want to know if there are any alternatives rather then QT Pro I can use to transcode some clips for the software. I also want to write future clips to a codec that my software can read from the first list (lossless).
  • Ben G unguren
    January 20, 2012 at 9:50 pm
    Install the FREE version of QuickTime. This will install a bunch of codecs on your machine, but you won’t be able to export anything from qt without paying. THAT is why you then get MPEG Streamclip, which is a free solution for exporting, and it will allow you yo use all those qt codecs you just installed.
    I prefer qt pro over MPEG , but when I hop on a friend’s machine and he needs a couple quick exports I go this other route. But you could use this for a full production workflow as well (it allows for batch exporting, etc).
    Ben Unguren
  • Walter Soyka
    January 20, 2012 at 10:38 pm
    [Christopher Rotter] “I need to take a few clips and convert them, so the software that I’m using can read them. In my original message the first part of the message I posted a list of codecs. Those codecs are the ones that the software can only read. I want to know if there are any alternatives rather then QT Pro I can use to transcode some clips for the software. I also want to write future clips to a codec that my software can read from the first list (lossless).”
    I have been asking you to detail your workflow a bit so we could give you better information on codec selection, but you’re still keeping us in the dark. You won’t get good answers this way.
    What software are you using, what are your system specs, and what is your current workflow like? (And does this have anything to do with After Effects?)
    I Googled a couple phrases from your list of codecs, and I’m guessing you’re using Lightworks. Have you reached out to any other Lightworks users about workflow?
    Lossless and uncompressed codecs require some serious horsepower to play back in real time. Unless you have a fast computer and a very large and fast RAID, you have to consider compressed HD, like MPEG-2 I-frame HD or DNxHD.
    Walter Soyka
