Paige Karmen
December 30, 2010 at 8:20 amIt’s working on Windows Media Player perfectly fine with just the DivX Codec Pack. But won’t work on SV or WMM!
Paige Karmen
December 30, 2010 at 9:20 amI lied.. my AVI files are working with the x264vfw installed!
John Rofrano
December 30, 2010 at 2:19 pm[Paige Karmen] “my AVI files are working with the x264vfw installed!”
Yea, I couldn’t figure out why it wouldn’t be working because that works for me. Glad you figured it out.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Paige Karmen
January 1, 2011 at 2:29 amWell, technically it works on WMP, but it’s still not working on WMM or Sony Vegas, which i want it to work on SV, but if it works on Windows Movie Maker i can save it so that it will work on Sony Vegas. See that’s where the problem exists, it was like that from the beginning.
John Rofrano
January 1, 2011 at 3:20 amHave you tried Vegas Pro 32-bit? It may just be a 64-bit codec problem.
~jr
Paige Karmen
January 2, 2011 at 3:06 amThen why wouldn’t it work on Windows Movie Maker? Because i already uninstalled Sony Vegas once, and it took a while to get it installed again!
John Rofrano
January 2, 2011 at 1:35 pmI don’t know anything about Windows Movie Maker (sorry). You don’t have to uninstall Vegas Pro 64-bit to install the 32-bit version. Both versions will remain installed at the same time (and in fact, you should have both versions installed because they are lots of plug-ins and codecs that don’t have 64-bit support).
~jr
Paige Karmen
January 3, 2011 at 3:30 amOkay, but when you open the 32-bit version will it be opened seperately from the 64-bit version. Or will they merge or something when you open it?
John Rofrano
January 3, 2011 at 3:38 amThey are the same program running in either 32-bit or 64-bit mode. Think of them as one.
~jr
Paige Karmen
January 5, 2011 at 7:47 amSo once i install it, does that mean that mean i have to do the keyen thing again? Or is it completely universal and i just go to open sony vegas? How do i know whether or not i’m using the 64-bit mode or the 32-bit mode? Because i already downloaded, ran as administaror, and clicked next to everything and then after while i think it said finish that i clicked on, is there anything mroe that i have to do?
